2 mobos - 1 choice / new build
ASUS has a much nicer BIOS and an extra PCIe x4 slot.
MSI has a nicer color scheme and is cheaper.
iconiK has it!!! I have the ASUS and couldn't be happier. The BIOS is quite nice to use and my particular board/proc OCs like a banshee. I've had good experiences with MSI as well, so I suppose it comes down to the features/price point YOU need/want.
Gigabyte also has some nice Z68 offerings. I'm quite sure [H] has some good reviews of Z68 MBs.
Also, consider your personal experiences with particular vendors.
Checkout the Biostar TZ68A+RCH board and with the left over cash use it on your video card.
Those of you with the Asus P8Z68 Pro, I have a question. Does it take a while for the bios to finish post? My Maximus Formula takes like 15s~20s before W7 starts loading. That's with quick post option enabled. I understand it's a full featured board so it would take a bit longer than a budget board where it's almost instant. I'm hoping it has improved significantly.
Thanks all. I'm pretty much set on one of the two in the first post....unless there is something comparable that I should consider. They're probably both equally as good, just looking for some other thoughts.
Is the 1394 and two extra SATA 6GB ports worth the $50 price premium the PRO has over the vanilla -V to you? Or the GD65 over the G45 on the MSI side?
