2 Mice, Any easy way.
Well I have the Cordless MXDuo and with the price of the MX510 down where I would like it to be, I think it would be nice to have a lighter mouse for gaming.
How could I set this up to run and still keep my MX Duo for everyday tasks.
I dont want to have to Plug in-->Unplug-->Re-Plug and so on and so forth.
Any way to have them both set up?
EDIT: Win XP 64, and no I dont have the Logitech Drivers, and no I cant get them setup until logitech makes them x64 compatible.
Don't know if you can do it with USB & PS2, but I just had both my Logi MX900 (BT) and V500 - A mini lappy mouse - connected to my PC, and both were operational at the same time. Both are USB Mice.
Edit: Just using the USB HID compatible driver as well. So you should be good under WinXPx64
you should be able to plug in the second mouse and use it when you like...
they both work if you plug them both in. i have an mx3100 keyboard/mouse and an mx518 plugged in to the computer right now. i throw the mx1000 in the craddle when i game, nothing to it.
Yup, you can hook up two mice and have them work together with no problems. Not sure about ps2, but I've had two USB ones going at the same time.
got my mx700 in the PS2 port and i just plugged in my old mx310 to see if it would work
works fine..no logitech drivers installed
I got a crappy mouse that plugged into the PS/2 and when I game I flip it on its back and plug in my mx510 into the usb and play with that... dunno if that helps you but thats what I do.
You can plug in as many mice as you have USB ports, and they will all be active all the time. In other words, just plug 'em both in. Same with USB keyboards.
ANyone ever tried hooking up 2 mice and moving them in opposite directions :p.
I was having one of thoese days where I was easily amused.
ROTF, ya that shits funny man.
lol, me and a friend of mine was having like a mouse tug of war one day, it was funny....
