2 loops 1 reservoir (help)
My list of Watercooling parts:
Swiftech GTZ
EK Asus 1 NB/SB
Swiftech 4870 MCW 60
6 90 degree rotating bits power fittings
6 High flow fittings
2 220 Swiftech radiators
2 Danger Den CPX Pros
2 Danger Den Acetal T Fittings
7/16ID 5/8OD
EK 150 rev2 Reservoir
This will be inside an antec 900. The radiators will be in the front and the top below the 200mm fan.
CPU loop will be: Reservoir>pump>rad>cpu>NB>T-Fitting>Reservoir
GPU loop will be: Reservoir>pump>rad>gpu>T-Fitting>Reservoir
I know how to split the reservoir into two parts for the pump, but my situation is, If I make the T-Fitting with two 90 degree fittings on the sides and have those connect the two loops and the top fitting go to the reservoir. Will the flow from the side of the T fittings combine and exit through the top fitting?
Something like this: (sorry for the sketch up in MS paint)
Blue Will be CPU loop
Red Will be GPU loop
Black will be radiators.
Green is EK 150 Reservoir.
Light blue are the T-lines that will be the split and connectors into one after and before the reservoir.
Brown will be pumps. The Pumps will be side by side so you won't see them in the sketch up, when you see the loops separate just pretend there are two pumps there in place.
The sketch below the case will be the T-lines before the reservoir.
