My auntie has a Medion Pc (p4 515, 2.93ghz, 533mhz fsb, 512mb ddr pc 3200, dl-dvd burner, seagate .7 80gb sata) and she got a virus so she took it to a local pc repair place. They opened it up and found 2 leaking caps and it has a virus, so they wanted $450 to to fix it, and instead of fixing it they recommended her to get a new one. So she ended up saying screw that, so she brought it to me to fix. So after opening it I found out its socket 775 so i looked around and i cant find any ddr1 motherboards that are socket 775.
So should I end up getting 2 new caps and fix it? Or tell her to get a new cheap pc at futureshop that is a amd athlon at 2.7ghz, 1gb ram, vista home basic, dl-dvd burner for $319 (cheapest one there)? Or tell her to get a $150 cpu, mobo, ram kit (A64 3800+, Asus M2N-MX SE Plus, 1GB DDR2 667)?
Thanks
EDIT: Or should she get a cheap 775 mobo and some ram?
Thanks
