hedron
- Apr 24, 2008
I have two PCs. One Slackware Linux and one Win7. The Win7 has 2 network adapters. One connects to the internet and the other to my slackware box, which is used as a glorified external hard drive.
The problem is that I can only connect to the internet when I disable the network adapter that is connected to my Slackbox. I thought I had it solved when I made the internet adapter a "home network" in the "Network and Sharing Center", but not only do I get a very sluggish connection sometimes it drops off altogether.
I tried enabling internet connection sharing, but then the ethernet adapter connected to my slackware box can't indentify itself.
I tried menubar > advanced > advanced settings > setting my internet adapter at the top of the list, and I really thought that this was the solution until I put my computer to sleep and turned it on again and it was back to not working unless I disable the adapter connected to my slackbox.
How can I set which adapter to use for which service?
