Ok, I have 2 questions. Here goes:
1- I'm currently running an ASUS A7N8X-E Deluxe mobo, I use the onboard audio, and do not have a soundcard installed. This has worked fine for me untill recently. I bought some Creative Gigaworks G500 speakers, because I wanted 5.1 surround sound. My primary use for these will be gaming, although I may want to watch DVDs with them as well. I got the speakers set up, and tried to set up them in 5.1 mode with my NForce onboard audio, when I ran into a problem.. The rear surround speakers won't work correctly.. I've tried setting them up numerous ways, with every plug into every socket on my motherboard.. the best i can get is the front, center and sub speakers working correctly, but when i use the audio testing tool, the "surround rear" test come out the front speakers. In the setup program, it has options for 4 speaker and 6 speaker setups... im not sure if the "6 speaker" setup means 5.1, or 6.1, but either way, I can't get them to work correctly. The speakers work, i've used them in 'upmix' mode and when i was swapping inputs around.. The mobos manual is very vague about all of this, and doesn't really offer any solutions. Does anyone know anything I could do to fix this?
2- I'm a gamer, and I think that one solution to #1 would be to buy a soundcard.. I'm not a huge audiophile, and gaming is a priority, so obviously, the creative audigy2 zs comes to mind.. are there any other "gaming" soundcards that would get me better in game performance? I'd probably go with an Audigy ZS, for as cheap as i can get one, but I'd like to be aware of other options (i haven't bought a soundcard since the original SB Live Value many many years ago, so I'm not really up to date on any of this.. especially all of the terminology..) I really just want a good soundcard that will complement my new speakers (and will be compatible for all of the surround sound/THX, etc features) for gaming and some HT use, without spending alot on a top-end soundcard..
Whew, thats alot more than I planned to write.. Anyways, any input/suggestions would be appreciated!
