2 GTX 1060s off the same PCI-E cable?
next-Jin
I have an EVGA G2 850w PSU and am wondering if I can power 2 1060s with 6 pin connections off 1 PCI-E power cable that has 2 separate 8 pin connections at the end.
Thanks guys.
Yes probably, but depending on what loads your psu currently handles, what else is on that 12v rail, and what you intend to do with those 1060s, it may be a bad idea.
I think you'll be fine. 6 pin connectors only draw 75w, so multiply that by 2 you get 150w, which is what the 8 pin connector is rated for anyways.
An 8 pin can do 150 Watts. You said you have a cable that has 2x 8 pins.
That means that cable can do 300 Watts by itself. Yes, two 1060's can be powered by it.
My PSU at full load only pulls 360 watts from the wall with 4 1060s as it is. Adding another 1060 should put it at 50-55% load which is what I'm aiming for atm.
