2 dual channel pairs?
0zymandias
Is this possible/wise? I have 2 512 sticks of generic pc-3200 sitting around, as well as 2 sticks of ocz 3700 (I think that's the speed). Right now I have the ocz running in dual channel mode on my msi neo2plat mobo and was wondering if I could stick the other gig in the other dual channel slots? If this works would it throttle my faster memory to match my slower? And, if it did would this make it less desireable than 1 gig of faster memory?
your k8n neo2 will automatically drop the ram speed to 166mhz and raise the command rate to 2T. if you play games like BF2 and FEAR, it'll probably be worth it.
well, no harm in trying and letting us know which is better for you, is there? ;)
nah, i'll be EXTREMELY surprised if there's any physical damage. worst case scenario, it's unstable, but i promise it'll return to normal when you take two of the sticks out. if not, you hurt your windows install and you have to reinstall it. memtest before booting into windows is reccomended :D
0zymandias said:
Aside from the firey explosion, no. :p
Now if you WANT to see this....
A computer shop near my home has a stick of DDR mounted on the wall that someone bought and then tried to RMA.....with ugly black scorch marks on it.....
It seems that someone managed to put the DDR into the slot BACKWARDS!!!!!!
And it caught fire!
Then they tried to RMA the memory!
People can find really creative ways to be dumb. :p
I added the other memory, didn't boot with one configuration so I switched to keeping memory sticks of the same type in the same color slot. Booted fine and seems stable. I didn't notice any performance difference (good or bad). I might try benchmarking it once I put together my new system.
The biggest difference that you'll notice is that there will be a lot less paging.....
Try opening a lot of apps or running *cough*BF2*cough*
