2 displays and full screen mode
KD28
Wondering, if you used 2 displays played a game in full screen mode how does it split the display. Does it automatcially place it only on 1 screen and have the other desktop/blank or does it split it across 2 screens? IF the latter is true, wont it look weird since the picture would be very 'long' and not tall enough.
I have an 8800gts 320mb and was thinking of getting 2x22" widescreens.
It will play it on your primary display, and your secondary display will have your desktop, or any windows you already have open on that window.
I suggest you disable one monitor while gaming; dual screens really kill framerates, since the gpu has to push twice the pixels.
ah ok ty. Do i need to turn it off in the display properties or would simply shutting off the monitor suffice?
Disable the second display, simply turning the power off won't help anything.
UltraMon is a great utility that really helps get the most out of multi display setups, and it has provisions for disabling your secondary display, and it's a lot easier than going into display properties.
