2 Different Wireless Routers. Same Low Speed. What gives?
My cable connection usually gets around 5megabits downstream, whether I'm using my computer directly connected to the router or if I'm using wireless, but about 2 weeks ago, all of a sudden my wireless speeds started consistently being a max of 1.6 megabits downstream. what the...?
I have an old linksys router, and I thought maybe something was wrong with it, so I went out and bought a buffalo whr-hp-G54 wireless router. I hooked it up, and I still have the SAME exact problem, I'm getting a max of 1.6 megabits downstream using wireless. I don't understand what's going on. Nothing in my house changed!
I tried the channels 11, 6, and 1 (on both my old linksys and the new buffalo), and my max speeds on wireless remain 1.6megabits downstream. Someone please help!
Sounds like a problem with the PC you're using? You mentioned you already changed the wireless router out yet the wireless speeds remain low. That would leave the wireless NIC in the PC as the cause of the problem.
Maybe check for newer drivers for your wireless card?
You wireless card is dying unless you have changed the postition of any large items of furniture. which could have been degrading the signal.
I don't know how it could be the NIC's because I have 5 different computers that can be on the network, and each one gets the same maximum speed. I'm totally clueless here. It doesn't matter whether 1 laptop is on, and the other 4 computers are off, or if they're all on at the same time either.
Does the problem dissapear if the computer is connected wired?
