2 CPU Venice????
Iargonaut
Hi,
I just tried a system diagnostic software from http://www.lavalys.com/ called "Everest". There it says that I have 2 CPUs and that one is disabled by the user....
No do I have a castrated X2 or is it simply a clutch in the software or the X2 support of the chipset?
Mainboard: FN25P//SN25P
Thanks!
Only way to be sure is to remove the heatspreader. Sounds like a bug in the software.
