2 Computers + DLINK ADSL Router | Configuration help
Hi,
I have two computers one running windows xp SP2 and the other runs ubuntu. The main xp computer has 1 network port built into the ASUS P5P800 motherboard (it's a Marvell Yukon Controller), and it has the router via a USB connection for the ADSL.I seem to be having trouble getting the ubuntu machine on the internet.I have had it on and have it set up right i think.The trouble is when i enable the yukon LAN it shows up as everything is alright but the ubuntu or the xp pc can't access the internet, yet when you disable the yukon LAN it allows the xp computer to connect the internet again.
e.g configuration
Dlink DSL-502T Router
The router is DHCP assigned and the ip is: 10.1.1.2
The Gateway is: 10.1.1.1
Marvell Yukon (onboard LAN on XP)
ip address: 192.1678.3.1
subnet: 255.255.255.0
gateway: 10.1.1.1
Ubuntu Machine
ip address: 192.168.3.10
gateway: 192.168.3.1
And internet connection sharing is enabled via the router connection.
can anyone see something i'm missing or any errors in configuration.
Thanks
