2 channel input vs. 6 channel
Broon
is there any downsides to using 2 channel input onboard instead of 6 channel e.g. audigy for connecting the Z680's to? will it still sound the same?
zachary80 said:
2 channel = stereo
6 channel = 5.1
anotherguy159 said:
If the digital connections are used, the quality of stereo output could be enhanced. If analog, then the quality will be the same. The digital connection would sound better because I would tend to believe that Logitech took more efforts to make a decent DAC stage than the MB manufacturer. You will not get surround output from games with a digital connection from that MB.
