Hi guys
1. Resolution doesn't set back to the previous session
It always boot up as 800x600 even i set previous session as 1024x768
2. Auto-restart after playing awhile of CS
After 5 minutes or so, my pc will restart..
Both problems i have try to use diff drivers and also put a fan blowing my pc with opening the casing. The problem is still there...any idea guys?
Spec:
AMD Athlon XP 1800+
512mb DDR333
OEM Mobo
HIS ATi 9600
Spec:
AMD Athlon XP 1800+
512mb DDR333
OEM Mobo
HIS ATi 9600
