2 Basic cards trying to decide which one is better my needs
The 8600GT is a far superior card and should push those 22s fine, though I'm unfamiliar with the graphics requirements of that game.
Even that 7300GT for $47 is good enough. But, I would get a card with Dual DVI instead though so you can have both display connected via DVI connection.
Thanks for pointing out the DVI
I gave my brother one of them I'll need to buy another
here are the 2 I would look at,
MSI NX8600GT Twin Turbo GeForce 8600GT 256MB 128-bit GDDR3 $79.99 after mir
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127306
Which comes with a free copy of the new game Witcher!
or
XFX PVT84JUDD3 GeForce 8600GT XXX 256MB 128-bit GDDR3 $69.99 after mir
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150229
Also you may want to look at this version for a little more memory since you are running monitors, I think it may help no?
EVGA 512-P2-N757-TR GeForce 8600GT 512MB 128-bit GDDR3 $99.99 after mir
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130290
