http://coolerguys.com/840556010081.html
Need to connect a front panel device to a Mobo header? USB/Firewire? This device comes with the cables. The are bundled together on the front-panel end. But if you dissasemble it (jewelr's screwdriver) and slap the pins into some old pc-audio cable connectors, you have shielded USB cables with pin headers on each end.
I have seen these cables go for 8-9 dollars for ONE elsewhere.
This is definitly a [WARM]|Deal!
-PHiZ
-PHiZ
