2.8e temp with stock hsf
gotskill10
Hi,
Im getting 50 C as the cpu temp running a stock 2.8e p4. Is this normal and ok? Let me know guys. Thx
fine for a "E" but i would say to look into better cooling
are you useing the thermal pad that came on it or thermal paste
im using the stock pad and fan. Im going to put a volcano 7+ with thermal paste. What temps should i get with that setup?
We don't generally use motherboard temps, mobo temps are always innacurate! As long as your system is stable, do not stress about temps, temps are not the only sign of a bad system!
yea but they are to be used as a guide
do not go over 60C load on a intel or it will not last long
That's more appropriate for a AMD CPU. ;)
as a rule i try to keep my 3.0E under 55under load
abit eq says it is at 60C no load[but abit is high by 10C]
im working on water so yea
also i have that bad boy clock as
1.5ghz
100fsb
400 quad bus
nice underclock huh:)
