2.8c and voodoo1?
mattsmall
since the voodoo1 runs with the fsb would it try to make my videocard run at 200mhz instead of the 66mhz?
a voodoo1 gets its core and mem clocks from the fsb so i wanted to know if the bios of the card would reset at 200 back to 66
If I'm understanding your quesiton right, no, the motherboard has a divider that should keep your PCI bus at 33MHz (not 66). Same goes for your AGP (which runs at 66MHz by the way.)
This is based on two things though...
First, you have to have your divider set right.
Second, why the hell do you have a Voodoo 1 with a 2.8GHz P4?????!!!!!!!!!
some emulators work best with glide. Ive got a voodoo 4 4500 in my emu box.
got it from work, just wanted to try it out and see what it was like.
Hey I've got a Voodoo 3 3000 that is still a viable option as long as you're not trying to play games that are recent.
I built a glide box... for just glide games, and emulators
P3 733/133
256MB pc150
Asus Mobo
voodoo5 5500 agp
30GB IBM Deathstar! <--sucks
Win 98SE! w00t motherfuckin w00t
and it rocks0rz
Say what? I hope you are joking with that statement. Besides, PCI runs at 33 Mhz, not 66 Mhz. I don't recall there being an AGP Voodoo1 card.
There was no AGP when the Voodoo came out.
I understand on trying to see what that card can do, I used to have one and still have it in a drawer.
I got a voodoo 5 5500 in my Mandrake linux 9.2 box, it's great!
AMD 1000MHz Athlon Thunderbird slot A (yes slot A w00t)
Gigabyte GA-7IXE AMD chip set
Voodoo 5 5500 AGP 1.18 bios
Soundblaster Live!
Gravus Ultrasound 512K (not installed yet, woot)
AMD PCnet PCI 10/100 NIC
old school dual floppy drive (5.25 and 3.5 drive in one bay)
samsung 40x cd-rom
Maxtor IDE 10 GB HD
