Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
My temps have skyrocketed in the past 2 weeks, they used to be about 97F idle and at the most 120 under load. Now for some reason the temps are now 110 Idle and 140 Load. Im using the stock intel heatsink.
have you moved your rig around? have you checked the heatsink... is it loose? try re-applying the heatsink.. Is one of the fans not working? etc... what are some of the other factors you might have forgotten?
