2.8 C Multiplier
Vs17
Hey I'm running a 2.8c in a P4P800 Deluxe motherboard and was wondering if there is any way to unlock the multiplier (so that i can lower it and increase my fsb for the RAM without pushing the cpu too far). I also don't know if that would be found in the P4P800 Deluxe BIOS or not... thanks for nay help
That feature wont be found on any Pentium 4 board. You'll just have to raise the CPU and FSB both togethor.
if you have an ES then you can change multi, otherwise you can just raise FSB to OC
but chances of getting that is very slim
