Hi folks, I've got an ide tape drive that works flawlessly with the 2.4 series of kernels + ide-scsi, but I want to upgrade to the 2.6 series. I've had no luck making it work with ide-tape, so I'm stuck with using ide-scsi ( not that this is a bad thing. If it works, it works, who am I to argue with that? ).
Problem is, ide-scsi doesn't seem to work under 2.6. I have scsi emulation support turned on under devices, and ide tape support disabled. I have scsi support turned on.
dmesg normally should indicate that ide-scsi is attached to the appropriate device ( /dev/hdd in this case ), but there is nothing like that when I boot the 2.6 kernel.
Am I missing something? The 2.4 kernels I'm using are stock Fedora kernels, so they may be doing something wonky I don't know about.
