2 570's 850watts?
Aus10
Will this psu work for this setup? Thanks Was looking at 2 460's before but want something that will last awhile...
http://www.newegg.com/Product/Produ...07001&cm_re=pcie_power-_-17-207-001-_-Product
Asus p6t
Intel i7 920@ 3.5ghz (planning to take up to 3.8-4)
2 evga gtx 570's superclocked
Maybe that psu
Corsair dominator 2x3gb adding another 6gbs
Xspc rasa kit
Corsair 600T case
Monitors are acer h213h 24" and a 22"
Thanks
That works. You can cut it down to a 750 watt if you wanted to, but I guess it's sometimes nice to have that extra headroom.
Yeah i kinda wanted a little bit of head room because with my 700watt now i have to spend another bunch of money instead of getting a great psu from the start. I was also looking at a corsair hx850 but there more expensive. Plus in the future i plan to add more stuff and maybe clock everything higher so that extra power will be nice i think...
Will 2 570s work with the Corsair 750HX in a non overclocked rig with 2 SSDs, a Velociraptor, and a 500GB WD Caviar Blue?
Seasonic M12D 750 watt work fine with an overclocked 1090T, 2 overclocked 470's, one old 300gb drive, one Velociraptor, a 24 watt pump, 6 fans, and two 12" cold cathode tubes
