l008com
- Jun 20, 2002
I need a 2.5" to 3.5" adapter so I can start putting some 2.5" drives in my 8 Bay Mediasonic drive tower. But this drive tower doesn't have SATA "cables", its connectors are permanently fixed inside the case, much like a Mac Pro's SATA drive connectors. So you just slide the drive in. So I need a 2.5" 3.5" adapter that keeps the SATA ports in the same exact place, relative to a 3.5" drive, so it can slide right in to my enclosure's ports.
I've searched around but everything seems to center the smaller drive, which is no good. I've seen some more complex carriers that center the drive and have a separate small board that 'moves' the sata ports. I suppose that could work, but I'd rather have an adapter that just puts my small drive's ports in the right spot. In this particular enclosure, there are no side rails, just a handle type thing you install on the non-port end of the drive. So an L shaped bracket that was essentially just a space filler, would totally work. But I've never seen anything like that.
