2.5" to 3.5" adapter
Andhar
Console Gamerz Rulez
I recently bought a 2.5 to 3.5 cable adapter now the only problem is if I do decide to use the laptop hard drive how do I mount it in a space for 3.5 hard drives, I may have to make a custom (ghetto) bracket.
Andhar
Yeh I know about that one, kinda wish I had made the decision to buy it BUT I only bought the pin converter.
My friend paco suggested that I use an old floppy casing to do it or just use some double sided tape or zip ties to hold it in.
SO I will try that first and see how it does.
