If you were referring to me? - that would had been this thread/post: http://hardforum.com/showpost.php?p=1040436586&postcount=78....
I seem to remember some [H] forum-goer working on a 2.5" NAS enclosure. I can't find the thread anymore but it might or might not involve one or two 5.25" bay 2.5" drive enclosures.
There is also the C2570D4i from ASRock
Wait... you're storing SSDs, not hard drives?
Stick hot glue or duck tape in between them, slap the whole thing inside some miniature case, and you're golden...
I was thinking of something like Rosewill RS-MI-01, but this one doesn't seem to have 2 x 5.25" bays. Does anyone know something similar size and shape but with 2 x 5.25" bays?
I use double sided tape, but I was looking for some better off the shelve solution.
what do you guys use for power connectors when they are that close together?
Probably something like this.
put plastic between the ssds as spacers with double sided tape.
Something like this would supply more than enough spacers when cut up.
http://www.walmart.com/ip/Nature-Saver-Recycled-Plastic-Clipboards-1-Capacity-Blue/23225203
