2.5" SSD into HP LFF
cafcwest
ML330 G6 server, want to configure with (4) 2.5" SSD drives. Looking for how to install the 2.5" drives into the 3.5" "LFF" hot-swap bays of the server.
I know Dell makes a 'hybrid' hard drive caddy/tray that positions a 2.5" drive in the correct location within the 3.5" footprint so that the drive aligns into the SAS connector. Does HP make such a caddy/tray as well?
Asking because my Google-fu has failed on this question.
Supermicro produces the adapter you're looking for. MCP-220-00043-0N is the part number. This will only work if the drive tray screws onto the sides and not the bottom.
Looks like that'll do the job - thank you sir!
