Stanley Pain
- Apr 5, 2001
Alright here's the setup.
I have two 4mbit DSL lines in the house (on 2 different physical lines).
1 DSL line is hooked up to a router that my current computer is on.
the 2nd DSL line will be coming in shortly, which I will have direct access to the modem (the one upstairs I don't have direct access to).
What I am wondering is if there is a way to multiplex the two lines together? or have 2 IPs on 1 computer?
I remember something about possibly being able to load balance accross two NICs. I have a vauge idea how to do this under Windows server (Having 2+ nics in the computer and setting up load balancing across the 2 IPs or something), but I'd like to know how/if it is possible under Linux as well.
to re-cap:
DSL line 1 has a 192.xxx.xxx.xxx IP (through a router) going into a Linux box that is acting as a router/gateway/nat/server (10.1.1.xxx internal IP).
DSL line 2 will be running to the Linux box and will have direct access to the "outside world".
I'd like to "combine" both these lines in some way to maximize both connections, or multiplex them into an 8mbit line.
Cheers,
Mr. Pain
to re-cap:
Cheers,
Mr. Pain
