2 4K LCD
SunnyG
Hi, I’m interested in getting two 4K 32 inch LCD monitors, my PC has VJ card is Nvidia GeForce GTX 295 so is this compatible with these monitors? Kindly inform me about this.
Sorry I’m not understand so please give me bit detail. Kindly:)
I know that my system is old and I will be buying a totally new system in the near future (i9 & graphic card, etc.) But for now please recommend me the best 4K 32 inch LCD monitors to get .
He already responded to you. The GTX 295 is not capable of displaying in 4k. He might be curt and to the point, but also accurate.
You need to upgrade the graphics card in your system to a GT 1030. That is the cheapest device that can do two 4k monitors (one DisplayPort, one HDMI):
https://www.newegg.com/Product/Prod...14137140&cm_re=gt_1030-_-14-137-140-_-Product
I assume you don't want to play games here, since that GPU is from 2009? Then you can get away with only paying $100 to add this feature to your computer.
The maximum resolution supported by your existing video card is 2560x1600. 4k resolution is MUCH HIGHER, at 3840x2160 (TWICE THE NUMBER OF PIXELS).
