So here's my problem the CPU runs at 2.4GHz and I want to go higher but I can't. I have reached 2.45 but that's not enough. I have seen people with the same CPU running at 2.7GHz (+/-100MHz) or even 3000+ Venice running at this speed with value RAM and some even have stock HSF. Some say that at least 20A (or 20mA?) is needed on the +12V rail and I have 18A but then again I have seen people going beyond 2.4GHz with 1.4-1.45V. First I thought the motherboard had problem going beyond 250mhz*10 ref. clock so I tried 272*9, 4HT, divider 140, so mem was ~188mhz (376) at 2.5-3-3-8, and it booted so I tried 273 and it failed to boot and increasing the Vcore did not help. I noticed that loosening the timings to *3*-3-3-8 at 272 crashed what does that mean the mem doesn't like loose timings?
P.S.
Someone had the same problem with a K8N Neo4-F and said that going back from BIOS 1.B0 to 1.6 solved the Ref. clock problem so I'm using 1.6 now but as you can see it did nothing for me other than giving me a wider range of mem dividers.
P.S.
