2.4C vs 2.6C
badjoke
im gunna get either a P4 2.4C or 2.6C
Im not much of an OCer but my friend optional is
Is it worth it to pay te extra like $20 for the 2.6 or just OC the 2.4
I really dont wanna OC unless i need to
If you don't plan to OC, then the 2.6 will suit your needs. But if you want to OC, the 2.4C is where you want to be.
Personally, I'd get the 2.4C, that way you can always overclock in the future so you don't need to spend more than $20 on a nice HSF to upgrade to around 2.9+
