2.4a @ 3.6 HELP
sTYZ
I FInally did it!! Yay for me it is cpu burn-in stable and everything. BUT i need more lol but the problem is my vcore is at the max for my IS7 (1.775) although my actual vcore is 1.6 - 1.65. Is there a volt mod for my board? and what waterblock/pump/rad combo would be good for this proc? Right now idle is 44 and load is 55. I currently have a Kingwin watercooling setup but i modded it so i can have both rads external. I think that i do not get enough flow for this thing to cool my computer effectively. Any comments advice etc would be great thx.
um... scratch some of the insulation off the copper wire off of a inductor and find out what the voltage really is, people thing the ic7 is mad unstable because winbond chip sucks ass soo much, but it couldnt be more stable...
on the ic7 what causes low cpu voltage compared to what you set is a weak power supply
i have an is7 :p but i have a 480W thermaltake should i get a new 1?
TT arent the best....
Whats the 12v rail spec?
Go for Enermax, Antec, OCZ, etc....
