I have what seems to be a very interesting puzzle.
I have a Linksys Router WRT54G
I have 3 laptops: Compaq (Vista, full-size) Asus (XP, netbook), Macbook (OSX 10.6, 13")
I have a working internet connection and WiFi turned on
Two rooms are involved. The room the router is in, and the Room on the other side of the stairwell
The Stairwell is roughly 12' wide (from plywood-then-sheetrock wall, to stairs, to sheetrock-sheetrock, to wooden stairs, to sheetrock-then-plywood) the router is sitting 3" away from the wall on one side of it. The laptop(s) is(are) sitting roughly 3" away from the wall on the other side of it. There are no power cables in the path of the wireless (they're run through the ceiling roughly 6' above the router/laptops)
The Compaq Holds the signal and connects with ease, surfing the 'net and streaming 640x480 videos
The Asus Netbook will connect and surf/stream, but will randomly dissconnect and will randomly completely lose track of the router (showing "no wireless connection available")
The Macbook will occasionally see the router, but tell me "network timeout" when trying to connect, and will usually NOT see it at all (if I tell it to "join other network" and type in linksys, it can *find* it, but still gives me a timeout error)
I was having issues with the linksys router to begin with, so today I installed the Tomato Firmware. Same issues happened, nothing changed.
Now, my question is this:
What is wrong, is the router not sending properly, or are the laptops not receiving properly?
My guess is the Compaq simply has a better card in it, while the other two (Apple+Asus) use lower-powered cards to conserve power (I made sure to turn off "power save" mode on both before testing just to make sure it wasn't software-controlled)
I also tried changing channels in case the default one was congested by other RF devices, no dice...
Using hardwire Cat-6 from router around wall to laptop works perfectly (but rather detracts from the mobility of the laptop...)
Any suggestions are welcome...
