2 260gtx compatability sli question
mikejustis
Will I have any problems running the Sparkle GTX260 216 with a Nvidia GeForce GTX 260 216?
hmm, had the same question, I want to run a Palit gtx 260 with a BFG gtx 260. I would like to know as well.
as long as the model of card is the same they will work in sli
if one card is slightly faster then use that as ur main card
What if you have a 192 SP GTX 260 and a 216 SP GTX 260, then?
Hm only a guess but I think the 216SPs performance would be knocked down to the level of the other 2 cards, since they have to each take an equal amount of workload.
been running a XFX GTX 275 and Inno3D GTX 275 for a while now..now problems both are factory overclocked and as long as they are sync speeds..no problem.
I don't like the 192 + 216SP chance though as that could be an issue.
