2.1 system under $100?
infin|ty
Hi all,
So I've got the Klipsch THX 2.1 system, and it's been giving me issues for the past couple years and I'm sick of it. It finally has quit on me and the sub is completely blown.
I want some decent speakers, is there anything that can approach this sound quality for less than $100 if possible? Cheaper the better.
Thanks!
If you're okay with used gear and can fit an audio receiver nearby, then hop on craigslist and get a receiver and some used speakers.
I'd prefer a cleaner looking setup that could avoid a receiver. I guess my main question is how do some of the Logitech systems sound? I've been looking on Amazon but I obviously can't hear them.
I would say get a small tamp and pioneer speakers to start. Then get a sub later.
There isn't a Logitech setup that sounds close to what you had. I'm voting T amp and 2.0, too.
