COKE CAN said:Got you. I just wanted it for use at home som I can cleanly install it into my lab. I guess I will just grab one of the cisco ones.
annilation said:symbol makes wireless ap that you can rack mount circuit city has them in each store.
mobiux said:You are talking about a wirleess controller, not the AP itself.
AP's are mounted throughout the store, controller is in the rack.
if that's what you are looking for, then cisco has one, it's kinda pricy though, cheapest rackmount is over 6g's for 12 access points. The 25 AP one i just purchased cost 9 grand for the hardware, 3 grand for the 1 year support and 2300 for the wireless control software to do all the tracking tricks. Woo hoo cisco wallet rape.
COKE CAN said:Are there any inexpensive rack mount wireless access points available? Just to use for my laptop.
Malk-a-mite said:Honestly if it's just so you can access the network with your laptop.... grab *any* WAP/Router and stick it on top of your top most router/switch in your rack.
*shrug*
Since it's just a home lab there isn't much reason not to go with the simple, inexpensive, low tech route.
