1TB WD Caviar Black Not Recognizing
FuNiOnZ
Just started a new build, installed everything after alot of trial and error with the SSD not wanting to show up, and now i've reached a dead end with my new 1TB drive. I've tried switching between the red & black ports, having it set by itself and trying to format through win7 install screen (it doesnt recognize it), bios wont recognize it, i've pretty much run out of ideas. The following is what happens when I plug it into my hotswap bay on my 800D :
Ok so I open up Intel Matrix Storage Console and it shows this
http://i47.tinypic.com/6jpy7q.png
Soon as I push in my 1TB problem child of a drive into the hotswap position of my 800D, it refreshes the windows (I assume this means it detects something) and then this happens
http://i46.tinypic.com/9fpg79.png
As you can see it makes one of the perfectly normal functioning drives invisible on the list, but still doesn't list the 1TB drive.... Anyone have any suggestions/ideas/buckshot?
