cageymaru
- Apr 10, 2003
This a decent deal from Woot for $249? Wonder which manufacturer it is? My guess is Samsung as the specs look identical? Less than 3 hours left at any rate!
https://computers.woot.com/offers/famous-maker-1tb-msata-internal-ssd?
Blame frankmansal for linking it to me.
Famous Maker 1TB mSATA Internal SSD
3D V-NAND Technology
Innovative 3D V-NAND flash memory architecture breaksthrough density, performance, and endurance limitations of today's conventional planar NAND architecture. Famous Maker 3D V-NAND stacks 32 cell layers vertically resulting in higher density and better performance utilizing a smaller footprint.
TurboWrite Technology
Achieve incredible read/write performance to maximize your everyday computing experience with Famous Maker's TurboWrite technology. You can obtain up to 2x faster random read write speeds than the award-winning Famous Maker. The Famous Maker delivers class-leading performance* in sequential read (540MB/s) and write (520MB/s) speeds. Plus, gain optimized random performance in all QD for better real-world performance.
Improved Energy Efficiency
The Famous Maker delivers significantly longer battery life on your notebook* with a controller designed and optimized for 3D V-NAND that supports. Device Sleep for Windows at a highly efficient 2mW.
Advanced Encryption
The Famous Maker comes fortified with the latest hardware-based full disk encryption engine. The AES 256-bit hardware encryption secures data without any performance degradation and complies with TCG Opal 2.0. Easily integrate into Windows with Microsoft e-drive IEEE-1667 to keep your data protected at all times.
Dynamic Thermal GuardProtection
Famous Maker Dynamic Thermal Guard constantly monitors and maintains ideal temperatures for the drive to operate in optimal conditions to ensure the integrity of your data. The Thermal Guard automatically throttles temperatures down when temperatures rise above optimal critical threshold. This protects your data while maintaining responsiveness to help ensure your computer is always safe from overheating.
Famous Maker Quality Components
As the industry SSD leader, Famous Maker uniquely designs, develops and manufactures products in-house. That means you're getting fully-optimized solutions for a better performance without the risk of compatibility errors.
Shipping Note: Shipping to Alaska and Hawaii is not available for this item.
A physical address is required for delivery. No Military or PO Box shipments available
Warranty: 90 Day Woot
Details
Form Factor:: mSATA
Capacity: 1 TB
Interface: SATA III
Memory Components: 3-D Vertical
Controller: MEX
Performance
Max Sequential Read : Up to 540 MBps
Max Sequential Write : Up to 520 MBps
4KB Random Read : Up to 97,000 IOPS
4KB Random Write : Up to 88,000 IOPS
Environmental
Power Consumption (Idle) : 0.05 mW
Power Consumption (Active) : Read: 3.5W
Write: 4.3W
Dimensions & Weight
Width : 4.9 mm
Depth: 29.9 mm
Height 50.8 mm
Weight 0.02 lb.
Advanced Encryption
Details
Form Factor:: mSATA
Capacity: 1 TB
Interface: SATA III
Controller: MEX
Performance
Environmental
Write: 4.3W
Dimensions & Weight
Width : 4.9 mm
Depth: 29.9 mm
Height 50.8 mm
Weight 0.02 lb.
