1TB HD for running OS Question
baboyizm
Right now I've got XP Pro running off of my WD 500gb HD (WD5000AAKS) and its doing a decent job as far as speed goes. Now I know the 750gb version has the same specs as the 500gb version. Would the 1TB Western Digital drive give me performance that is close? Should I stick with what I have or pickup a 750gb drive instead?
Thanks
What exactly do you mean by 'performance'. Generally, larger drives tend to preform better because their area density is larger. But, if your hard drive works fine, then the only reason to really 'upgrade' would be size.
The Hitachi TB drives are a good bit faster than either the wd or the seagate drives.
The thing you need to look at is the read and write times of the drives and compare them.
Also you should look at which drive has the most cache. If you go 1TB, get 32MB cache.
