aggiestudd07
- Oct 1, 2006
I recently had to RMA my ram and OCZ sent me a new kit. When I booted on the new kit, it listed as running in 1T command rate, which i confirmed with cpu-z. i would like to restore my overclock this weekend that i originally had (3.2GHz).
should i change the command rate to 2T or can i leave it at 1T?
Basically, i was under the impression that all ddr2 ran at 2T, and i just have never seen a kit running at 1T. i was also under the impression that you had to loosen the command rate to oc
