1T or 2T on Core 2 Duo
Wall7486
I'm wondering whether all these nice overlocks on the Core 2 Duo are 1T or 2Ts?
Gotta be 2T I mean when you're talking about 4-4-4-12 or even 5-5-5-15 its gotta be
1T has been pretty big amongst memory settings for awhile. Either way this is one of the latency timings where lower is better. Even though my cpu is in the mail, I can say 2T is definitely not going to be faster. It's the command rate. Usually the performance lost is not worth a few MHz. It's like two steps back because the MHz difference isn't enough on mem to overcome. Not many people OC with 2T. Only when it is more or less necessary for a stable rig. Like when I got a gig pack on NF2.
I had this funny experiance with the conroe and the reurns after overclocking past 2.7ghz on the e6300 and i saw that i could go higher but it wasnt worth it cos i was loosing Float and \Int effeciency.
So in the end after 2700mhz i just tighten the latencies and gained a little more bandwidth which should have been the real goal.
So all these 3.4ghz - 4ghz overclock are on 2Ts I assume. I just can't imagine CAS 4 to 5 timings with 400+ FSB at 1T.
All i can say is that if the timings are loose they are running high clocks and wasted bandwidth and not efficeint, overclocking is worthwhile if you are tweaking the system and the means justify the end.
My last overclock on thew E6300 is that its running at ddr800 speed and the timings are 4 4 4 9 , which is quite tight and still efficient which needs to be , it still needs to be slightly more tighter to see overall return on conroe , a very efficient cpu as it is.
