Ok, Im ready to take the plunge into water cooling. Im still on the fence of exactly how I want my setup. Here is my system specs.
LGA775 3.2GHz
1.0 GB DDR2 Dual Channel
80 GB SATA
200 GB PATA
BFG Geforce 6800GT OC
ASUS P5AD2 Deluxe
550W Power Supply
CoolerMaster Wave Master Aluminum Case
Dell CD-RW/DVD-ROM
No Floppy
Items Im looking at
CPU Water Block: MCW 6002
Chipset Water Block: None
GPU Water Block: DD 6800 or Maze 4 with heatsinks if possible
Pump: DD 12V Laeng
1/2" Radiator: DTek - Pro 120 (depends on decided setup)
w/ DTek Shroud w/120mm fan
Reservoir: DD Bay Reservoir High-Dens Polyethylene
Tubing: 1/2" Tygon tubing
Primary Questions:
Radiator vs. Heat Core
1. What is the diff?
2. Is the DTek Pro 120 considered a Heater Core?
3. If I get the DTek Pro 120, Im likely going to mount it on to the rear fan position of my case with a fan using the MCB-120 Radbox radiator/fan housing by Thermaltake. Does this seem like a feasible solution?
4. Or, Ive seen some users that have radiators on the inside top of their machine. Would that be more ideal and if so, what would be a good radiator to use and how would I mount it? I would prefer to use a radiator that does not require soldering or anything like that.
5. Or, Ive seen some users mount the radiator on the outside top of their rig. Does this seem like the ideal solution?
6. I can cut and drill my case, Im ok with that, but are their pass-thru barbs I could get that would allow me to drill the holes and mount the pass-thru barbs, or will I have to MacGyver it with silicone or something.
Ive heard nothing but good things about the blocks Im looking at and I know the pump is known for a whinny pitch noise, but Im not too concerned about the noise level and it doesnt really require and moding. If you can recommend another no mod more quiet and equally reliable pump that will give equal performance, then Im certainly open minded.
I intend to mount the res in a 5 ¼ bay. From there Ill feed water to the pump, then to the radiator, then the cpu, then the vga and then back to the res.
Again, Im very new to all this, but very excited about investing the time, energy, money and learning experience into it. Some of the rigs Ive seen displayed here have been truly inspiring.
Im sorry if my questions are noob or possibly repeat something someone has answered before, but I sincerely appreciate any and all help that can be provided.
gurumagic
LGA775 3.2GHz
80 GB SATA
200 GB PATA
ASUS P5AD2 Deluxe
550W Power Supply
Dell CD-RW/DVD-ROM
No Floppy
Items Im looking at
Pump: DD 12V Laeng
Primary Questions:
gurumagic
