Hey Folks -
I'm a first time over clocker. I've never done it before, but i just built a new system with overclocking in mind. Its a core i7 920 on an ASUS p6t Deluxe, 6GB of ocz ram system. I'm not sure if you need anything specific as far as system specs go, because i just want to know if these numbers are safe. I followed an over-clocking guide on bit-tech. I just lowered the numbers a tad because i'm "scared" i'd mess something up being my 1st time.
Numbers:
CPU Ratio: 20
BCLK: 190
DRAM Freq: DDR3 - 1523 MHz
CPU Voltage: 1.30
CPU PLL Voltage: 1.90
QPI/DRAM Core Voltage: 1.3
CPU Differential Amplitude: 800MV
CPU Temp (Under Full load) 58c
GPU Temp (GT280) 84c
I played crysis warhead at 1680x1050 at max settings with 4xaa for about 30 minutes and noticed absolutely no trouble. My pc starts up much faster, the sidebar gadgets load faster, and the computer seems much zippier now. I'm successfully running at 3.8 GHZ, on air, which i'm very happy about.
I just want to know if those temperature and overclocking numbers are pretty safe for me. I'm not sure what temps are "normal" when overclocking.
---edit---
I got a BSoD while playing crysis warhead after 30 some minutes of playing. I didnt' write down the exact message, but it was something about a cpu core not receiving the timing expected. I went into the BIOS and cranked up the voltages a bit to more mirror what bit-tech guide had put.
CPU volt: 1.35
CPU PLL: 1.96
QPI/DRAM volt: 1.35
Everything else was left the same. I ran Prime 95 for about 30 minutes and received no errors or crashes. The temp of the CPU was 91C under full load. While i play crysis, its about 60C
Just want to make sure i'm not going to screw anything up at these extreme temperatures.
Numbers:
CPU Ratio: 20
BCLK: 190
CPU Voltage: 1.30
---edit---
CPU volt: 1.35
CPU PLL: 1.96
QPI/DRAM volt: 1.35
