JamesfromDFW
- Mar 19, 2016
I'm about to pick up a MBP Late 2013 model with an i5 cpu and 500GB ssd. Any suggestions for being a first time user of a mac?
Remember the correct reacharound technique.
Stick with it for a few weeks before making any judgements. Everytime you wonder how to do something, ask google and learn, and after doing this a few days you'll be proficient in no time flat.
Any items worth buying, docks? usb3 vs thunderbolt hard drives? 4K monitor? I'm guessing I should treat this like a windows laptop as far as accessories....
First thing I usually do is fix the horrific default "natural" scrolling direction. Other than that, just learn the basics for touchpad gestures and keyboard shortcuts. Every so often I get a wild burr up my ass and switch between PC and Mac - you'll be fine! Also, that's a great year!Good luck!
It's all preference. I prefer Apple's default scroll direction vs PC's... I also have trouble moving back to Windows for hotkeys and the position of "Command" vs "Windows key" on PC keyboards.
As for the OP: I would say there is nothing to buy. Use the default and stock apps for a bit. And just Google a lot. You'll eventually figure out shortcuts and hotkeys which is generally the best way to get around.
There are generally free apps for everything you'll want or need, unless you need Pro app stuff. But then that is all available the same as it is on Windows. (IE: Adobe apps, Microsoft Office, etc).
Was on honeymoon, picking it up later this week.No updates from the OP? He must have already bought a new MBP till now and we are still busy giving him suggestions lol.
the later versions of OSX should be able to mount the volume in at least read-only mode. basically just connect it, save off the data you need, and then reformat it to a mac compatible fs.
Only thing I would add immeidately - get a external USB HDD so you can use Time Machine. It's not the most robust backup solution, but it's nice to be able to restore from if nothing else. Doesn't need to be anything fancy or expensive, just plain USB with some decent size so it can hold your stuff.
I've been looking at docks but not at $200+ pricing for TB2 ones, are the USB3 just as good?
I've never had an issue with any USB drive - I do reformat them as HFS+ before using them for Time Machine, but just for straight file copies, thumb drives often come formatted as FAT and OS X works with that. I believe on NTFS OS X defaults to read only (with 3rd party NTFS drivers available), but don't quote me on that.
For backup purposes, yes, USB is plenty good enough. I do have a TB2 backup drive - it's unquestionably faster, but for Time Machine, that is a slow enough process as it is that the extra interface speed doesn't really help you that much, and for that purpose, I'm still using some USB 2 drives, and it works just fine.
The only reason I'd go TB would be if you are wanting to run large files off of it rather than the internal storage (Virtual Machines, video editing, etc). If you don't need to run stuff live off the drive, the extra speed that your paying for with TB is mostly wasted.
For Time Machine (and other backup software, Carbon Copy Cloner is another great utility that has a lot more depth to it), capacity means more than speed honestly - the first backup is the only one that takes forever, after that it's mostly just small incremental updates.
Be careful with Chrome on OSX, it can be a battery hog (it uses a lot of CPU).
Safari is actually quite solid on OSX.
All i use my current Win10 computer is net reading, youtube watching. as far as my external drive - pic, video, mp3's. I'm thinking about recording youtube videos online. I would like to play my retro games on my MBP with my 360 controller as well. I may get a dock for hard drive, ethernet and KMM purposes.
Glad you brought battery life up. I have some questions. MBP Late 2013 should get around 7-8 hours? How long should i keep it plugged in for? Is it bad to keep it plugged in if i have it "docked". Who's a good place to go to get the battery replaced? Can Apple help locally if i have problems with it without apple care? How can I transport my favorites from chrome to safari?
The PS3/4 controller is easier to get to work with in OSX. I wonder why? You used to have to get the drivers separately. Now the driver package is preloaded into the OS, so pairing a PS3/PS4 controller is very simple. I used to play SNES emulated games all the time while overseas. Handy to do on a MBP... built in Bluetooth has its perks, wonder why it never caught on as much on PC?
Battery life is 100% dependent on what you're doing. Listening to music with the display off could probably net you more hours. Watching video (especially video that has to be decoded/decompressed/processed while streaming (internet) will net you less (maybe 4-6?). Doing just docs all day will probably set you in that 8-10 hour range squarely. While gaming you'd be lucky to get 2-3.
Also things to consider is how many apps you have open at once and of course the brightness setting of your screen.
You can keep it plugged in everyday if you want. Apple generally recommends that you at least partially deplete the battery everyday however just to keep it in good operating order. So, at some point in the day, unplug and burn 25%+/- or whatever and plug it back in. The smart battery will distribute wear, so it will use different cells each time. No need to go from 100%-0% everyday as a result.
Apple does do battery replacement. It's more expensive than third party, but their smart batteries aren't to be toyed with. I've had friends go with third party replacements and regret it almost instantly. Their battery life turned to crap and they had swollen batteries in less than a year. So spending the (I think $140) is worth it to do from Apple themselves when the time comes. They also will generally give you same day turn around, which is convenient if you have an Apple store near by. The battery, installation, and etc of course will then be warrantied by Apple for a year... which is another perk you wouldn't receive going third party or doing it yourself.
Yes, Apple Geniuses will diagnose hardware/software issues for free. If you want a repair done, then of course it will cost you money. Applecare would simply make those repairs free (provided it's a hardware/software issue that wasn't created by user error, neglect, damage, etc).
Protip: Make sure to make an appointment before going in. If you live in a major city (where most of the Apple stores are), Genius appointments can be booked several days or a week in advance (sometimes, also depends on time of year). So doing a walk in might mean you end up waiting for several hours... or never getting a meeting at all. Obviously a waste of time.
Safari has an import feature like FF and Chrome. Goto:
File => Import From => Google Chrome
Easy peasy.
DAMN! Thanks for all of that, unless you can suggest anything else, i think everyone has helped move on from Windows....thanks to all!
You're welcome. That more or less happened for me too in 2008. I still (VERY rarely) use Windows to play an occasional game or two. But from a productivity and work perspective (which is basically 99.9% of the time), I'm in OSX. If you have other questions or need help figuring some stuff out, feel free to post some more.
Well I hit a road bump today, my job didn't put in my vacation time, so i will be unable to get the MBP this weekend. Anything I should read online while i wait another two weeks.....
Your previous post also said "failed on downloading Chrome".. That sounds ominous. One thing to burn into your cranium when it comes to Macs are that these are "soccer mom" devices. Things don't arbitrarily fail in some unclear way unless something is genuinely broken. If something isn't intended to work (like installing newer versions of Chrome on a version of the OS too old to handle it now), it should tell you, in clear english, of that incompatibility. "Fail" is not a thing on Macs unless either the hardware or the OS (usually the hardware) is defective.so i copied all my photos from windows onto my usb3 thumb drive and it would only read about 12 of 3k of what was on the drive, any ideas?
As far as your USB issue, I'd check that the USB stick is good in other computers. Macs don't have a random "can't read certain parts of a USB" thing. Either the USB is quirky or the USB port is bad. Try other USB ports too, those Macs have one on each side.
