1st build...am I doing this right?
Cintirich
Hi folks,
I'm in the process of building my very first DIY gaming rig and I wanted to check some things I've done so far to make sure I haven't screwed up. :p
I'm still waiting on the RAM and Video card to arrive, so I'm not in a huge rush.
So far, I have mounted the cpu & fan, installed the mobo, and mounted the DVD burner.
I'll list the build and then give you my questions, so far.
Mobo: Gigabyte 965P-DS3
Proc: C2D E6300
GPU - eVGA 7600 GT
HDD - Seagate 7200.10 320 Gig IDE (converted to SATA with a Rosewill bridge)
Optical - Samsung SH-S182D Dual-Layer DVD Burner
Case: Antec Sonata II w/450W psu
RAM - undecided
Okay, here's where the questions start:
  1. The case has a header labeled "audio" leading from the front panel...it also has a bunch of single pin dongles hanging off. I think I leave all that stuff unconnected since I'm not plugging any audio devices into the front panel, right? Answered, thank you!
  2. There's tandem wires, blue and black - 3 prong header, coming from the psu. Is this for a sensor? If so, where does it connect? Answered, thank you!
  3. Next, in the area where all the front panel connectors are, there's 2 green pins that my manual shows as the reset switch, but I don't see any headers that are labeled to go on that. Am I looking in the wrong place? There is a reset switch on the front panel. Answered, thank you!
  4. There's a 6 pin power connector coming from the PSU labeled "PCI-E". I don't see where that would plug into the mobo. Is it used for a certain component? Answered, thank you!
  5. Is my DvD burner supposed to have a connection going to the "CD IN" connector on the mobo? Answered, thank you!
  6. Gigabyte has applications called Q-Flash, @BIOS and Xpress Install. Do these features enable me to flash to the latest bios, install drivers, ect...without the need for a floppy drive or memory stick? Because I don't have either of those at the moment.
  7. On my DvD burner, I set the jumper to Cable Select. It will be the only device (for now) on the IDE channel. Will this be okay? I have heard the with the DS3 board, there can be problems with optical devices, although I'm not sure what's involved with that. Answered, thank you!
Any answers would be tremendously appreciated and I'll update this list as the build moves forward.
Thanks!
Rich
[edited for spelling and clarity]
I'd suggest pulling the mobo out. You will want to test all the components outside of the case before installing everything. Its much easier to troubleshoot the system if its out of its case. Setup the mobo on top of its box (not on top of the anti-static bag). Test just the essentials first, then add things one by one. Start with the PSU/Mobo/CPU/RAM/Vidcard (one stick of ram). Then if that POSTS, setup your BIOS settings properly. Then start adding the other components one by one... the other stick of ram, first hdd, any other hdd, the optical drive, etc.
Yes, you could leave these unconnected.
Yes, its the fan sensor for the PSU's fans. You could plug it into any free fan_header on the motherboard.
Which one can you not find? the header on the mobo or the connector from the case? I think you can't find the connector for the front panel switch. Look again, it should be labeled RST or something like that. If you don't see the label, trace the wires from the reset switch on the front panel.
This plugs into the video card, if it needs one.
This isn't necessary. You could use it if you want, but most people don't.
I assume they do.
Yes, that will be fine. If not, change it to master and make sure its plugged into the last connector of the IDE ribbon cable.
You might want to check the BIOS version on your mobo. If its old, update it to the latest one if you experience any problems.
I was mistaken, I did have the reset header set correctly. The one that's missing is the mssg status light header. I'll pull off the front of my case to poke around for it. The case may just have a LED for the hard drive activity.
I really appreciate the advice on that and the others you answered.
By the way, is there a way to tell what BIOS and revision my mobo is by looking at it or the box (sort of like cpu's)? Or do I need to wait til I boot it up?
Thanks!
Rich
I do believe that some of the top tier motherboard makers have been distributing software which will allow updating your bios from the internet while your computer is on.
if Gigabyte is one of those, then yes, you can flash your bios without a floppy or usb drive.
Remember, you really shouldn't need to flash your bios just because they have a new version out. Unless you have a specific problem which is fixed with a bios update, don't update
I don't think the BIOS version is on a label anywhere. You'll have to boot it up.
