brasscorpion
- Dec 21, 2006
Quick question guys-
My BIOS is an AWARD bios with a 590chipset on the MoBo. In the BIOS there is a setting labeled I believe "performance". I am assuming that this has to do with overclocking setting that are preset into the bios. Is this correct?
If so what kind of OC do you get when using these automatic settings...for example I have an AMD 64 4000+ @ 2.6Ghz. With these performance setting what should I see?
Brass
Brass
