Goals: build a relatively cheap, quiet, and fast PC. I wanted a SFF at first, but it just seems too hard to get it jacked up for good gaming and keep decent heat and noise management... and it gets pricey.
http://secure.newegg.com/NewVersion/wishlist/PublicWishDetail.asp?WishListNumber=4675414
I have an 8800GTS 640MB that I'll move into this box, and 2 1GB sticks of DDR2-800 RAM (g.skills).
Anyone got opinions, or know if the 520HX cables will be long enough to route under the MB in this case to reach the require spots on the P5K MB?
Is that DVD drive quiet? If not, are any others recommended?
I'm on the fence about getting the Q6600 quad-core instead of the e6750 dual-core...$90 extra right now for the quads. I do a bit of DVD encoding and video editing (personal), gaming, and a bit of virtual PC/Server for home labs...I'd benefit from the quad, but likely not all THAT much.
Antec P182 Gun Metal Black 0.8mm cold rolled steel ATX Mid Tower Computer Case - $169.99
ASUS P5K LGA 775 Intel P35 ATX Intel Motherboard - Retail
$139.99 $139.99
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply - Retail
$139.99 -$15.00 Instant $124.99
Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775 Processor Model BX80557E6750 - $229.99 $229.99
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
$109.99 $109.99
SAMSUNG 18X DVD±R DVD Burner With 12X DVD-RAM Write, LightScribe Technology Black SATA Model SH-S183L - OEM
$36.99 $36.99
Thermalright Ultra-120 Extreme CPU Cooler - Retail
$64.99 $64.99
Scythe S-FLEX SFF21D 120mm Case Fan - Retail
$19.99 $19.99
Subtotal: $896.92
Thanks!
$139.99 $139.99
$109.99 $109.99
$36.99 $36.99
$64.99 $64.99
$19.99 $19.99
Subtotal: $896.92
Thanks!
