Hi,
Thanks of the advice of the forum I ended up replacing my X600 with a PowerColor HD2400Pro.
I installed the latest drivers from the ATI web site (9.5 - I believe).
I have one problem: the selected resolution doesn't stick. Whenever I reboot, it reverts back to 640x480, 8 bit color. I can set it back from Catalyst. However, after the reboot it will go back.
Two more pieces of info:
1.) I can change the resolution only from Catalyst - not from the windows display settings dialog !!
2.) As a test I did run directx test. After the test comes back from the 3D test (rotating cube) the screen resolution reverts back to 640x480 as well !!
What could cause this?
