19" LCD with good viewing angle and response time.
Ford
There doen't seem to be any consideration on viewing angles of LCD on this forum. Most LCD's with good response time (TN) seems to have rather poor viewing angle according to reviews I've seen. I consider the viewing angle to be an important factor. If I move my head 30 cm I would like to have all the colors stay the same.
I've been thinking about buying the Benq FP937 does it have a good viewing angle?
No one here in Sweden has the Viewsonic VX910 on stock :mad:
(No Sony X-bright for me thanx, seen one of those in person)
I've seen the samsung 193p in person and its great. 20ms response time and great viewing angles (178 degrees) and the screen is gorgeous!
I've been leaning toward the 193P, how is it in games compared to a 25 ms LCD?
LG will release a couple of really nice 19" LCD's in a month or two, must have enough will power to wait, must have enough... ARGH, I can't wait!
For some reason, Samsung's response rates seem to mean little. I have the 172T (25ms), and I have to be really really picky to notice ghosting. For some reason, I seem to pick it out in Max Payne 2 (of all games) where you go into the little bullet-time thing when you reload; but then again, I think that little scene is supposed to have some motion blur for effect. I can move windows around really fast, and sure, there's ghosting there... but you see the same thing on CRTs. IMO, samsung makes the best LCDs around, even in the big-end LCDs (20"+). Yea, they're a lot more expensive than the rest, but I seriously think you're getting what you pay for.
In short, if it's a Samsung lcd, you can't go wrong :)
One quick test I try on LCD's is to move a window slowly, the text usually blurs and tears up quite a bit on a 25 ms xVA panel, but on a 16 ms TN+film panel it only tears a little and on a CRT it looks fine. That's why I've been sceptical about the 25 ms xVA panels.
There's not much difference in image quality between these panels, but I don't like the viewing angle on the 19" TN panels. I'd really like to buy a 19" LCD now instead of waiting a couple of months. Right now the choise is between a Samsung 193p and a Benq FP937. The 193p has a great viewing angle and ergonomy adjustments while the FP937 is cheaper and has a 12 ms response time.
I agree 100%. The importance of viewing angles cannot be emphasized enough and almost no one ever takes that into consideration when buying an LCD. I have a Samsung 710T and while it's a great monitor it's vertical viewing angles are pretty bad. Not only you can't move your head 2cm (vertically) without brightness changing but even when you sit DIRECTLY in front of the monitor you can see the top half of the screen is a bit darker than the bottom. I've seen many TN panel monitors and they ALL have the same problem. Some people notice it right away, some don't, but it's there. I think I'm gonna sell my 710T and buy a monitor with VA matrix which has much better viewing angles and picture quality. TN matrix monitors are good for games but are not a very good choice for work.
Oh, and if you're concerned about viewing angles, you're not going to like the FP937 :)
Ford said:
Great feedback, I just ordered a Samsung 193p :D
I'm gonna do the same thing. Although I've heard the 193P is not good for gaming it's still a bit faster than a regular PVA matrix monitor and it's picture is far superior to any TN matrix monitor. It has a high contrast ratio, very wide vewing angles in both directions and can display true 24bit color.
You're not going to be worried about the response time when you get near CRT image quality.
