i am planning to get a 19 inch widescreen lcd one day. my question is if the 19 inch widescreen would be compatible with games, if not then how do i fix that. should i get 19 inch widescreen or standard ratio. i can't go up to 20 inch
Most 19" wide screens have a native resolution of 1440x900. Make sure your video card can handle that resolution, or look at using PowerStrip http://www.entechtaiwan.com/util/ps.shtm
A lot of the newer games support this and other widescreen resolutions, but not all by any means.
