19" CRT Suggestion?
swinchen
Hi.
I am not happy with the quality of my LCD (VP201B). It is my first LCD and the screen door effect and backlight issue is a real turn off.
What are so good suggestions for 19" CRT?
Right now I am looking at:
Viewsonic P95F+
Samsung 997DF
NEC Mitsubishi DP930SBBK
NEC MultiSync FE991SB
Anyone of those stand out in anyone's opinion? Things to look out for/ things to avoid. Thanks! And sorry I am being such a pain on here. I have never had to get a monitor before and so far it is the hardest component I have EVER shopped for!
I have a FE991SB and it's been a wonderful monitor. Precise color reproduction (especially with a quality card). High refresh rates and bright as can be. The superbright functions are pretty useful for changing from normal settings to dvd/cinema settings quickly.
B
I have the Viewsonic A90f+ and it kicks ass...the P95f+ is a little better monitor, so I would highly recommend it.
swinchen said:
Really? I heard the text was blurry and the geometry was off....
Any decent monitor will allow you to change the geometry. Blurriness is probably a monitor-dependent problem. Go to a BestBuy or somewhere like that and actually compare monitors and decide which is best for you.
B
I still have yet to see a viewsonic that looks good to me. This is coming from someone who has a crappy envision 19" monitor. Anyways The Mitsubishi is incredible buy it.
Which one? 930 or 991?
B
Maybe it is just the Best Buy around here (Bangor Maine) but the CRT monitor selection is almost non-existent. They have maybe 2 or 3 monitors (including a cheap Mag monitor).
Circuit city isnt much better.
Nothing Viewsonic makes can stack up to the Mistu 930. I bought this P95f+ so I could run 1600x1200@85hz, but that's just too blurry. I'm forced to run it at 1280x1024@100hz; ah well. Look at the dot pitch of monitors you are considering (except Samsung, they measure differently), you NEED .24 for such high resolutions on a 19" CRT.
